1990 XJS won't start
New XJS owner here and optimistic novice.
Trying to get this beast back on the road. Picked it up from a local scrapyard with a misfire, had the mechanic take a look at it and run a compression test before I started pouring money at it. All cylinders were between 160-180 but the plugs were fouled something awful and he found a couple vacuum leaks. With that squared away she was running 90% better. Still seemed to be some hesitation when accelerating and idle seemed a little low.
Fast forward a couple days ... 5 out of the last 10 times when starting the engine took a bit to turn over. I would have to hold the key and it would crank several seconds before starting. Most recently while attempting to start it just would not turn over. Left it for a little bit, came back tried again and it wouldn't crank at all. Now all I have is just 'click'. Any thoughts on where to start?
You will need a DVM. There should be at least 12.8volts at the battery with the ignition off. To check voltage at starter you will need to use a meter when you turn the key the voltage will drop on the battery by upto a volt or two. You will notice the very large wiring to the starter this is because they draw lots if current. It is impossible to test with a light as the light draws current (if it is a large light can draw an amp or so) it will reduce the current available to the starter motor.
Check the battery if not I would supect the starter motor I have replaced mine twice the second time I installed a new reduction gear unit no more problems.
cheers
Warren
cheers
Warren
Charlene n John
09-28-2015 07:01 AM
Jaguar Forums Editor
Jaguar Press release
09-03-2015 10:38 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 12:43 PM
