1991 facelift 16" Wheels
No the axles are the same. You can fit 16" wheels, there I no issue. Just get a tire with the same (within 2%) diameter to keep your speedometer correct. There were two 16" tire sizes for the 7" wide wheels that came stock. 225/60-16 and 225/55-16. The later are smaller in diameter and will give ever so slightly better acceleration, with a smaller sidewall. Not a huge difference. Note: wire wheels are not as stiff as alloy and are about 40% heavier due to being steel, which is a trade off most are willing to make who want the look of wire wheels.
