1991 Jaguar XJ-S V12 seriously running rich
Old 12-13-2012 | 09:07 PM
alabbasi's Avatar
Default 1991 Jaguar XJ-S V12 seriously running rich
All, a buddy of mine has an XJ-S that he rebuilt the engine on after the PO cooked it. Ever since putting it back together, it's ran really rich.
We're talking black smoke and gas washing into the oil.
I don't know much about these fuel injection systems as I'm mainly a Mercedes Benz guy, but if it was an MB of the era, I would suspect a stuck cold start injector.
Any ideas where to start?
We've already changed the plugs which were completely fouled.
Al
Old 12-13-2012 | 09:52 PM
JameyXJ6's Avatar
That year doesn't have cold start injectors, so you can rule that off the list.
When I replaced the V12 in mine I had the same problem. After running just a few minutes the plugs were completely fouled and I found a ton of gas in the oil. I had already rebuilt the injector harness, so I started checking the wiring to the sensors and found multiple cracks in the insulation. Basically I just replaced all the sensor wires and ignition wires and the car started up and ran perfectly. Even though the wires weren't broken, the corrosion had created enough resistance to confuse the ECU, causing it to overfuel.
Old 12-13-2012 | 10:08 PM
alabbasi's Avatar
Thanks, that makes sense!
Old 12-13-2012 | 10:13 PM
Doug's Avatar
Excessive fuel pressure? Or raw fuel being ingested via ruptured fuel pressure regulator diaphragm?
BrentGardner
28
04-26-2024 03:08 AM
1100me
08-27-2020 11:37 PM
GuernseyJag
11-08-2017 10:40 AM
DrScientist
12-09-2015 07:36 PM
mrplow58
08-29-2015 10:44 PM
Quick Reply: 1991 Jaguar XJ-S V12 seriously running rich
