1992 Fuel Presure Regulator Needed
Figured out where my fuel smell from under the hood after a shut down is coming from. The fuel regulator is leaking through the membrane into the vacuum line where it eventually makes it back into the intake. Have not been able to find the correct model and Jaguar has listed it as discontinued. Aftermarket only lists the threaded style regulator for the XJS. Any idea what else would fit? Looks like Bosch regulator from the same vintage Mercedes could work, but have not yet confirmed it. Mine is a 92 transition model.
Received 10,979 Likes
Try Leroy Sorrell in Jax, FL. Classic Car Garage. email: parts@classiccargarage.net. I know him personally. He deals in XJS only. Has assisted me more than a few times finding NLA parts. Mention my name: Mert
Holly makes an adjustable regulator in the right range. It’s of good but not excellent quality and reasonable at $50. I’ll dig up a part number if anyone wants. You’d also need to buy a gauge for it, but you’ll have another lever to pull if you want to adjust your pressure off-spec.
smgdata (12-14-2018)
Grant Francis (05-15-2019)
beeturbo
06-16-2008 02:03 AM
