1992 XJS v12 ABS question
Our 1992 XJS V12 w/ 33,000 miles was pulling to the left under braking. The specialty shop I took it to (they work on Ferraris, Lambos, Alfa, Bentley, Lotus etc) thought it was the front brake lines... not. But now those are new. Under closer examination (bleeding), the left front expels brake fluid, the right front does not. Is there a specific component within the Jaguar ABS system one can pinpoint or do we replace the entire unit? If replacement is the only option, is their a rebuild marketplace as new may be hard to find... or so Moss Motors says. Appreciate any/all suggestions, thank you! Peter ps. Why am I doing this research vs. the tech? Because their swamped and my Jag is parked to the side while they "think" on the problem... I'm trying to speed up the "thinking" process.
Welcome to the forums Peter,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to advise.
Notsofast (07-15-2023)
