1993 XJS 4.0L belt replacement
I am in need of changing the air pump v-belt on my 1993 XJS 4.0L. I haven't torn it down yet but it appears that the air pump belt is too small to be removed with the clutch fan in place. Does it need to be removed or is there a trick to replacing it or "working" it off of the clutch fan?
All help and ideas are appreciated.
Thanks!
Thanks!
I know that I am going to sound a bit dim here, especially as I am on my 4th XJS, but which bit is the air pump and what does it do?
I assume that simple transatlantic wordage changes may be part of the problem (wing/fender, sump/pan, boot/trunk) but I have been scratching my head/**** for ages now wondering what the hell an air pump does (yeah, I know, it pumps air smarty pants) and why would you want one?
