1993 XJS convertible 4.0 Fuel filter
Timeisrelative (10-02-2022)
Ok, when I went out and looked at my front driver wheel well, I saw a large round plastic canister so I thought that was it. Then it occurred to me that it had wiring hooked up to it and what appears to be some sort of diaphragm. I need to find out what that is and go back out to the garage and look for the fuel filter. So, you are saying it's under the car on the drivers side in front of the truck?
The fuel filter location changed at VIN 188104. This is what Jaguar referred to as 1993.5 MY but I'm not sure if teh US used that designation.
After 188104, the fuel filter is behind the plastic cover at the rear of the left hand front wheelwell.
Before 188104, it's under the car at the rear as mentioned.
Hope that helps
Paul
Hope that helps
Paul
They are all just supersession numbers. So the most recent one is the only one available.C2C35417. It's also used in XJ saloons all the way up to the end of x350 production in 2009.
Paul
orangeblossom (10-02-2022)
