1994 6cyl O2 senors
Hi all,
I've been working on a solution to a stalling, starting issue. I get the code for 02 sensor. I bought one but then thought someone said that two are needed for up stream and two for down stream.
I I see one on top of the pipe and a wire that runs to a connector in the engine bay. I don't see anything that would indicate a second. My online repair manual only points to one. How many do I actually need per car??
Thx
Tony
Thx
Tony
Received 10,920 Likes
'Sometimes', with luck, an open-end wrench will do the trick. Best bet, tho, is to get an O2 sensor socket
Alltrade 1/2 in. Drive 7/8 in. Oxygen Sensor Standard Socket-648442 - The Home Depot
Scotlad (04-21-2017)
Hi there,
Got old O2 sensor out and the new one in. I took the car for a spin today in the heat of the day (to recreate the stalling issue from last time). I drove on surface streets with no issue. I got onto the highway and up to 75 MPH and it started to stumble/stall. I coasted off the road. After sitting for a few moments, it started and ran fine, just as the last time.
Any thoughts??
Tony in NM
Any thoughts??
Tony in NM
