1994 fuel lines
I'm in the middle of changing my fuel lines as well. I went to change the fuel filter and the lines are so rusted that the nut to the filter will not even turn without rust breaking off. I believe the feed line that runs from the filter is around 1/2 in. and the return line appears to be around 3/8 in., my sizes might be off, but close, I ended up buying a 25' roll of aluminum fuel line from the local auto parts store, with compression fittings and plan on installing my own line. I was told that the standard fuel injection rubber hose might not be strong enough over the long run, so I was advised to use metal or jaguar factory made rubber/plastic lines. Also, I would feel that stainless would be a very good chose, but expensive. If you go to a speed shop, I believe they have coated fuel line that will also not rust, but I don't know the price. I hope this helped.
the lines that come from the tank are steel breaded they had some rust, but I was able to wire-brush and prime... plus they looked expensive to replace.
Also, I was concerned about the diameter... you definitely don't want them too skinny because you won't get good supply... but I'm not sure what will happen if you get them too "fat"... maybe your pump work work correctly?
Received 10,876 Likes
The sucess of DIY pipe replacment depnds on skill, tools, patience, and the complexity of the pipes in question.....and how fussy you are about the appearance of the end result :-)
I've never been very good at it so I take pipes to a place like this.....
http://www.justrightauto.com/nw-tubes-hoses.php
....and have them duplicated.
Most decent sized towns will have a similar vendor, usually over on the industrial side of the tracks, so to speak. They often cater to truckers, farmers, manufacturing plants, etc. but they should have no problem at all with an ordinary fuel pipe.
The outfit above will duplicate a pipe/hose/whatever if you send it to them...providing the size makes it practical for shippping, of course.
If you really want pre-bent lines, I believe you can get them from Conventry west, at about $75 dollars each plus costly shipping charges, cause they are large. As I mentioned before, from the back to the front of the car the fuel line is mostly a straight line on my 93 ragtop, so I'm going to try it myself. I my end up buying the pre-bent if it doesn't work out, so Wish me luck!
1964Daimler
09-09-2015 04:50 PM
