1994 XJS C dash light with braking
If you have the handbrake on, the engine running, and press the brakes, this light illuminates, which indicates the bulb failure warning light system is working. If the handbrake is off, the engine is running, and the handbrake warning light switch is adjusted correctly, this light will illuminate if you have a brake light out. It will also illuminate for about 20 seconds when you turn the lights on and will stay on if you have a bulb out.
So either your handbrake is not fully off, or you have a brake light out, or the handbrake microswitch is out of adjustment and the circuit thinks the handbrake is on when it is not.
rama1200
05-18-2015 07:29 PM
