1995 Fog Lights - Shorting plug location
OK, I know there was a full discussion about activating the wiring at the front fog light location ... please humor this old guy, I guess I just don't get it! .
I want to mount a set of aftermarket fog lights on my '95 XJS L4 2+2 Conv. There were none mounted originally. I have purchased an aftermarket 94 95 96 Jaguar XJS front fog light shorting plug/harness on eBay. Now just where the heck does this harness go? Is there anything else that needs to be done to activate the existing fog light wiring? Thanks for your patience.
If you replace both switch sets as in the post link above and install the shorting plug in the connector above the left inside fuse panel to the matching plug, you should have all you need. The relay and fuse are already installed at the factory. The front fog light, when switched on, will light while in low beam headlight operation. If you flash your high beams the fog light, by design, will turn off.
Shelby676
XJ40 ( XJ81 )
06-06-2011 09:15 PM
Jaguareh
09-18-2010 06:42 AM
