1995 Top Fluid
Detroit Bull (12-29-2021)
I use transmission fluid in mine. Jus say'n.
Detroit Bull,
Can you give us a bit more info?
- What happens exactly? Does the top slow down and eventually stop in the halfway position? Or does it go normally to the halfway position and then stop?
- Does the top come back up normally?
- Does it always stop in the same position when you try and lower it?
- When you say the windows are stuck down? What does that mean? When you raise the top, do they come up? In case you don't know, there is an 8-second delay to raise the windows after the top is raised. You need to continue to press the switch.
- Are you doing all of this with the engine running? It eases the load on the hood pump.
Paul
Paul
Detroit Bull (12-30-2021)
I hope this helps.
