1995 XJ6 squeals
Received 10,920 Likes
Presumably you've checked the belts and they are tight, yes?
There's a decent chance that you harmonic balancer is delaminating. Most of us send 'em out to be re-bonded. Fairly common problem.
If you search the archives under "Balancer Delamination Squeal" or similar you should got lots of hits.
rgp (12-12-2018)
If your belts are the standard V belts. The pulley could be worn to the point the belt is riding in the bottom of the pulley, and not making good contact on the sides where it's suppose to. Take a new belt, and turn it inside out, then insert into the pulley so you can see how deep in the groove it will go. If the bottom flat/ narrowest part of the belt touches the pulley, it is worn, and should be replaced. If it is worn, It is very likely the cause of the squealing. Hope it helps.
Jack
Jack
I'll add that on the 96 XJS there was a TSB for a timing chain tensioner to be replaced and that stopped the squealing on start up and 90% of the intermittent squeal on random acceleration (doesn't happen every time) for me. The tensioners are fairly cheap and still available. But, I will be trying the white out line across the pulleys to see if the harmonic balancer is playing a role.
PETER GROVE
12-17-2018 04:39 AM
tommyknocker
12-05-2018 04:26 PM
