1995 XJS 4L Convert - Valet switch function?
My 1995 XJS 4L Convertible has a switch in the storage box, between the seats. It has a switch mounted on the inside forward face. Valet switch? The switch is a rocker type that depresses left and right. The right side is spring loaded to return to center. I'm unable to locate any info on this particular style of switch. Can someone please describe it's functions? While we're at it how can I re-code the remote that came with the car?
Cheers, Steve
Cheers, Steve
Hmmm...doesn't sound stock. As far as I know, there should be no stock switch in the storage box. I have a 95 as well. The PO of my car mounted a radar detector on the forward wall of the box so that the wires run under the skislope. Many folks have also installed spring loaded rocker switches or two separate switches to bring the rear quarter windows down independent of the top down switch, which in my car, doesn't work. I will be mounting and wring in quarter window switches very soon myself. Do you know if your switch works the windows? You said it's spring loaded to center in one direction only? How is it in the other direction?
