1995 XJS convertible top fluid
I just purchased a 1995 jag xjs 6 cylinder. Fluid is leaking from between the reservoir and the pump. I would like to know what the gasket looks like. Does anyone have a picture? Also, what fluid should i use? The local Jag dealer sold me Castrol 27LM9886 .(green fluid) I was told not to use this, after I put in a little to get the top up. Now do I have to flush the system? and How would I do that.
Any help would be appreciated.
Thanks, Ben
Thanks, Ben
Thanks, Ben
Thanks, Ben
Royco 756 Aircraft Hydraulic Fluid - SkyGeek.com
Spec is an ISO 13 viscosity anti wear hydraulic oil. The green Castrol oil is intended for the mineral oil systems in the 1988-94 sedans ( code named XJ40) and is the wrong oil for the system. It's too thick and will put additional strain on the pump. Depending on the amount and temperatures, I have heard of pump failures from using it.
If you live in a hot climate and didn't put much it, it will probably be fine. I don't have a diagram at hand, but I think it's an O ring for the seal? Not sure. If it's flat, you could use something like Loctite 515 Flange Sealer.
I have found aircraft hydraulic oil, generically known as 5606 spec is the right viscosity. It comes in A and H grades, A is an older spec, H is for "super clean" aircraft systems. Either works, use whatever you can find and is cheaper.
JimC64
03-02-2015 08:07 PM
