1995 XJS Lug Nut Problems
A very stupid question -This caps over the nuts thing is very confusing. On my '94 XJS they're quite loose, and the original tire iron / wrench doesn't properly fit over them. Am I missing a tool meant to remove the caps first, or do they crack with enough pressure, then I have to use a smaller tire iron socket to get the actual nuts off? I'm a bit confused about this system and don't want to damage anything. It's ridiculous that I have to ask post in a forum to get my wheels off, but I've genuinely never seen such a bizarre system, and I don't know whether I'm missing a tool. Also, it's interesting that there's nothing about wheel removal in the manual...
jpind, it sounds like you're having the same problem I was having. The caps are probably so loose that you can't get the correct size wrench/iron on them.
The procedure I described worked for me - basically, I took the correct size impact socket (22 mm for me, but double check your size) and hammered it onto each nut, then used a breaker bar to loosen them. I replaced every nut with a new one so that I wouldn't have the same problem again.
al_roethlisberger
09-11-2015 10:04 PM
