1995 XJS V12 engine knock
Hi
I need your advices, I brought my 1995 XJS 6.0l with 45 000 miles to my mechanic for an oil change, transmission, differential, brakes fluid and coolant.
In the process I was told there was an oil leak and valve covers needed to be replaced, I agreed doing the job.
Today they started the engine everything was OK for 15 minutes and then the engine started to knock.
My mechanic ( referred to me by my Jaguars owner club buddies in Montreal) told me that timing chain and tensioners needs to be replaced.
When I brought my car it was silk smooth running as a V12 should be.
Your inputs will be really appreciated.
Sylvain
Sylvain
Received 2,650 Likes
Sylvain (10-06-2017)
