1996 jaguar xjs O2, 4-wire, color code
Old 06-22-2023 | 07:30 AM
Softball60's Avatar
Default 1996 jaguar xjs O2, 4-wire, color code
Question regarding the O2 sensors on my 96 xjs, 4.0L.
My XJS has 4- 4 wire sensors for the O2 system.
Can you tell me what each of the wire colors mean.
I have a blk, wht, ylw, and red.
If I am correct :
1 = signal
1 = earth or ground
2 = heater
The question is “which is which”?
Thanks for your help
Softball60/Paul
Old 06-22-2023 | 07:40 AM
Vee's Avatar
Vee
White with Brown Stripe is Power
Blue with either Pink or Brown Stripe is Heater
Blue with Purple Stripe is Ground
and then solid Blue, Green, Red or Brown, no stripe is Signal
Jagrepair will have wiriing diagrams. The colors I've given you are the Jaguar Harness colors. Once plugged in, you should be able to figure out which wire connects to which?
Old 06-22-2023 | 11:32 AM
Softball60's Avatar
Vee,
As always,
Thanks for the support.
Softball60/Paul
Spokanejohn
08-04-2023 04:53 PM
Softball60
05-12-2023 07:16 AM
hoodun
01-15-2015 02:09 PM
BurnsAF
03-08-2013 04:08 PM
loudjag8
05-27-2010 06:36 PM
Quick Reply: 1996 jaguar xjs O2, 4-wire, color code
