1996 rear wheel bearing problem
Am I correct in assuming that you have outboard brakes ?
If you have more free play you are correct you will need a smaller shim, as it allows the bearing to sit tighter/closer in the races.
Having replaced many rear hub bearings it is very unusual that a new shim is needed, especially if all you have done is just renew the bearing.
What was the reason for changing ?
Have a look at this picture and just check that you have everything back in the correct order.
http://www.jaguarclassicparts.com/uk...-4-0-6-0-litre
The correct Jaguar tool went through the loose hub assembly and preloaded the bearing, a slight amount of drag was required.
If we assembled the hub and found that there was a bit too much free play we would take a very small amount off the spacer see item 8 (NOT THE SHIM) using a flat metal surface and some emery cloth. The only problem with this was it was time consuming, as it was trial and error, but our stores department never kept any shims so it was do it our way or order shims and have the car on the ramp another day.
Are you sure your free paly is in the bearing and not the diff output shaft bearing ?
Removed .010 from the spacer. Reassembled, no change. Removed the .121 shim and reassembled, lightly tightened. Still no change. Removed the hub and outer bearing . There is about .001 difference. Could it be the hub? There was no galling or color to the old bearings or the hub. Thanks for any help. Jeff
Finally back to it, was waiting on new hub nuts. When fully assembled the nut was torqued to 115 pounds after converting from Newton meters. Measuring free play at the hub,pulling straight out. I pulled right side apart and reassembled with No spacer or shim. Hand tightened ,reassembled. Same play ! I am wondering if the hub is bottoming out on the axel? Both sides when reassembled are as they were before starting. Losing hair over this! Thanks, Jeff
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
Fraser Mitchell
10-01-2015 04:06 AM
