1996 xjs 4.0….Black soot out of tailpipe!
Old 03-03-2023, 07:09 AM
Softball60's Avatar
Thanks for the responses.
Larry, I will contact you sometime today.
I probably not take a chance and drive it. I am in south venice….close by.
thanks
Softball60/Paul
Old 03-03-2023, 08:19 AM
RickE's Avatar
Let us know how it works out.
Old 03-03-2023, 01:18 PM
Keesh's Avatar
Originally Posted by Vee
Clean oxygen sensors are very different than new. They are parts that wear, therefore have a limited lifespan. They should be replaced if you don't know how old they are, ...
Installed four new oxygen sensors today, emissions like a new car
Timeisrelative (03-04-2023)
Old 04-25-2023, 08:57 AM
Softball60's Avatar
TO ALL,
After three (3) months of non stop working on a boat restoration project for my grandson……
I DECIDED TO…..
Well, let’s give it another go!
After meeting with Larry back in March ( Thank You for the help!….he was convinced it was not the catalytic converter…..I was not!
Although I was pretty convinced that it was the catalytic converter system……I DECIDED TO DO THE FOLLOWING
I pulled the EGR AND CLEANED IT (second time) AGAIN. The difference this time is that I also cleaned all of the ports with thin wire brushes and carb cleaner. I MEAN I REALLY SCRUBBED IT!!!!!!
It has now been two (2) days and no soot out of the tail pipe when it is cold started. I drove it around the neighborhood and the engine is running great!
I don’ t know if the EGR WAS CARBON BLOCKED OR SOMETHING ELSE CAUSED THIS ISSUE ON THE EGR…BARELY SEVERAL MONTHS OLD……..LOT’S OF CARBON/SOOT CAME OUT……MAYBE 27 YEARS WORTH.
Hopefully this is good news and NO EXPENSIVE CATALYTIC CONVERTER REPLACEMENT.
If anything changes I will let all of you know…..AND IT WON’T TAKE SEVERAL MONTHS CAUSE THE BOAT IS DONE!!!!
Softball60/Paul
The following 2 users liked this post by Softball60:
Greg in France (04-25-2023), ptjs1 (04-25-2023)
t2greene
04-29-2021 07:34 PM
rlysmthn
11-07-2011 01:06 AM
drat9000
04-28-2010 01:51 PM
Quick Reply: 1996 xjs 4.0….Black soot out of tailpipe!
