1996 XJS ac vaccum reservoir
Look in the engine bay at the point where, if the car was a RHD model, the pedal box and brake stuff would be. You will find a plate there covering the hole that would have been used to fix the pedal box. You may even see a vac line or two disappearing into this plate. Unbolt it and there is the vac reservoir.
Greg
