1996 XJS Convertible Issues
Hello. I have a ‘96 XJS convertible and have had continuous issues the the convertible top. First off, the parking brake. Half of the time I engage it the switch for the top does nothing so I keep resetting the brake. Eventually the switch activated and the top starts moving.
I consistently have have an issue with the sail panel windows. Sometimes they won’t go down, sometimes they won’t go up. Voltage wise, they have power and when power is applied they function normally. Can this all be stemming from a bad convertible switch or is there a separate sensor?
The windows are likely caused by the relays being at the end of their life. The up window circuit grounds through the down relay, and vice versa. Replace those relays ( the row of them above the battery in the trunk) with 40A relays (standard auto relays are 30A) and your problem should be solved.
Mac Allan (12-11-2018)
Correct. They’re first and last depending on the motion of the top. Just sometimes they don’t move at all, sometimes one goes. I usually have to repeat the act of putting the top up or down multiple times to get the windows to go up or down simultaneously so that’s what I’m trying to find out.
Both my windows were found unplugged when I was troubleshooting my rear windows not moving in either direction. In that case, it's easy to remove the two side panels where the seat belt goes. First remove the back seat both bottom and back cushions. Then just pull forward to release the snaps on the door jamb side, then lift slightly and move the enclosure inboard to reveal the hydraulic actuator and window mechanism and connector. Unplug and plug in the connector several times or just clean them and then try it.
orangeblossom (12-11-2018)
Hi Jagboi
Then it must have been a coincidence as neither the side windows or the soft top roof would go up or down on 'Carmen' my 1995 4.0L until I topped up the Hydraulic Oil Pump
After which everything worked as it should, so wondering if the Windows won't work unless the Soft Top itself goes up and down
Maybe one won't work without the other?
Hi Jagboi
Originally Posted by carsnplanes;1999876.
The pump works, just no oil.
https://www.aircraftspruce.com/catal...clickkey=60375
I got the fluid from Aircraft Spruce, it was the cheapest source for me. It's generically called 5606 fluid, and there are 2 versions: Spec A and H. H is the current spec for "super clean" aircraft hydraulic systems, A is the older spec. A works just fine for us.
Thanks for the tip!
gxs0lvi
08-10-2007 02:19 PM
