1996 XJS Fuel Pump Relay location
I have 3 relays in that location - 2 blue and 1 silver. I have assumed that the silver one is the fuel pump. The one way you can be sure is to check the wiring diagram and check the color of the wires going to the relay. Somebody may have put the wrong relay there if the connection pins are the same.
