1996 XJS seats - please help
Both XJS seats in my 1996 convertible are completely inoperable because the motors got wet. Unfortunately, they are completely stuck and cannot be moved. How can I remove the seats to replace what I need to under the seats? There is NO room whatsoever to get a wrench under the seats. Does anyone have a solution or am I the only guy in the Jag world that has this difficult issue. (I’ve called some professional Jag mechanics - no one has a clue.)
THANKS for any input!
Thank you!
dépend de ce que vous considérez comme facile.
Je ne savais pas que toutes les voitures étaient équipées d'une entretoise de 25 mm. J'ai enlevé le mien en pensant que quelqu'un l'avait ajouté pour s'asseoir plus haut dans la voiture!
I mean, depends what you consider easy.
i didnt know that all cars came with a 25mm spacer. i removed mine thinking someone had added it to sit higher in the car!
It has been a long time and I don't have a picture for you to look at, When you look at the front seat frame there is two small screws that you remove with their washers. You then grab the gold colored pin with a pair of vice grips and pull towards you. Repeat on other side of seat. You are trying to remove the seat motor drive pins from the motors themselves. You can then lift the seats out and repair. Have you checked the fuses yet?
Larry Louton
Larry Louton
Greg in France (02-26-2021)
Not sure it's the same for a 1996.
This eBay seller is selling that bottom rack. There do appear to be four screws holding it in. I'm not sure removing it would really do anything.
https://www.ebay.com/itm/Jaguar-XJS-...Cclp%3A2334524
