1996 XJS Tachometer issue
My 1996 XJS - 6 cyl convertible has a tach that cuts out intermittently. The speedometer, odometer and trip meter work fine so I'm thinking the sensor module is ok ( I understand the tach, speedo and odometer are linked to the same sending unit / module ) and it's simply a dirty or loose connection behind the dash (yes I am an optimist).
Once I drop the lower panel under the dash on the drivers side, does anyone know if Ill be able to actually reach the wiring to check / clean the contact points or should I attack it from another direction? Or maybe someone else has encountered this?
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
