1996 XJS touch up paint
The following 2 users liked this post by daverb:
orangeblossom (02-28-2016),
Terry007 (02-28-2016)
If your not an Expert painter, sometimes its better to live with it rather than risk making it any worse.
But having said that, there are Guys out there, that specialise in that sort of thing, so sometimes its better to pay up and leave it to them or leave well alone.
Terry007 (02-29-2016)
Without seeing a Photo, preferably a close up Photo of the Scratch, its a pretty much impossible question to answer.
I would let an experienced paint guy fix the blemish. If it bothers you enough to want to fix it, do it right.
The following 2 users liked this post by Vee:
I've known a few Guys who started with a tiny little scratch and ended up respraying the whole Car!
OB is right on this one /\
But if you must, if you're obsessed with it I would try the bottle and brush, use masking tape so only the scratch is visible give it a layer then buff the spot in a week then a polish for the whole car.
With a buff of the spot repair it should become level and nearly invisible
Good luck and may the force be with you
The following 2 users liked this post by Gunner01:
Received 10,892 Likes
The success of DIY touch-ups depends SO much on the size and shape of the scratch or nick, the closeness of the color match, the skill of the DIYer in question.... ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
My experience, FWIW, is that ...
- Fine scratches are best left alone. Dabbing/spraying/brushing touch up paint usually makes things worse. Sometimes much worse. By 'fine scratches" I mean something that you might see if, let's say, you lightly scraped the paint with your ring or wristwatch.
- Chips and nicks can usually be successfully touched up. "Successfully" meaning anything from near perfection to "Well, it's an improvement and looks OK from a few feet away". My Series III is white and I touched-up 15-20 chips on the front of the car. You'd never see the touch-ups casually walking around the car, 3-4 feet away.
- It is much more difficult to get a good result with metallic colors. Straight colors are much easier.
- Sometimes using a toothpick or matchstick or [use your imagination here] to apply the paint gives a better result than a brush. if the touch-up paint is too thick (common problem) things can get ugly. You end up with little blobs of paint dotting your car.
The following 2 users liked this post by Doug:
Has anyone had experience of using Coloured Polish or Scratch Remover?
Amazon.co.uk: coloured car polish
Terry007 (08-03-2016)
I have. They work pretty well to disguise fine scratches. They just fill the scratch with some pigmentation....or whatever it is. After a couple carwashes the scratch 'comes back'...but they you just reapply
Ok, I finally found the time to have my car detailed but before I do, I want to fix a small scratch caused by a bicycle (about 1 inch & half long and yes it will require touch-up paint ), so would you recommend:
High Gloss Clear Coat after applying the touch-up paint ? Remember I have a 1996 Black Jaguar XJS paint code 807 ,I believe.
and
An aerosol or a touch-up bottle with a fine brush?
Thank you
Terry
and
Thank you
Terry
anindyam
02-22-2016 07:00 AM
