1ntake sensor 92 4.0 XJS
That is the PCV Valve (Positive crackcase ventilation Valve )
Intake manifold vacuum is applied to the crankcase via the PCV valve. The airflow through the crankcase and engine interior sweeps away combustion byproduct gases. This mixture of air and crankcase gases then exits, often via another simple baffle, screen, or mesh to exclude oil droplets, through the PCV valve and into the intake manifold.
The PCV valve controls the flow of crankcase gases entering the intake system. At idle, the manifold vacuum is high, which would draw in a large quantity of crankcase gases, causing the engine to run too lean. The PCV valve closes when the manifold vacuum is high, restricting the quantity of crankcase gases entering the intake system.
