2000RPM when started?
My 89 XJS V12 revs to 2000+ rpm when first started, after putting in gear and putting a load on it with brake it drops down to 700-750 and runs fine then. How can I slow the initial start down some, no need for it to sit there and roar for a minute or two.
Thanks,
DickC.
Thanks,
DickC.
AAV on the rear of the LH cylinder head.
Big alloy thing with Lucas cast into it.
Has a dumb 90deg hose on top the WILL split when you remove it.
I have rebuilt hundreds over the years, and have a Word doco on that procedure if you want it. Drop me a PM, as its too big to attach here, due to Kodaks included in it.
dickc (04-10-2014)
If Grant's suggestion doesn't fix it, you've likely got an air leak somewhere else. A close inspection of any hose that goes to the throttle bodies is in order.
Under the RH throttle body there is a large connection that, if not connected...or if the hose connected to it is leaking, can cause a big RPM jump.
Good luck with it,
John
1987 XJ-S V12
63,000 miles
Good luck with it,
John
1987 XJ-S V12
63,000 miles
dickc (04-17-2014)
