26cu or 36cu dump
This may be an interesting read to you
VACUUM IGNITION ADVANCE / AJ6 Engineering
I would consider looking for a megasquirt thread or similar. Idk if anyone is going to have what you are looking for, but a detailed megasquirt build probably would.
By the way If your question was regarding ignition advance then this is handled by Marelli MED 123E, the Lucas 26/36cu handle fuel injection .
I tried to upload engine management training document but it's too large.
Click on mega link below to download this
https://mega.nz/#!HMxC2KAS!paXz-dCdK...xmaXZLtJmY4xPk
The following 3 users liked this post by Paul_59:
I don't have a dump of map from 26CU or 36CU but do have a document for training on Jaguar engine management systems for AJ6, AJ16 and V12 engines that may be useful.
I have been thinking about this too. I have a Megasquirt sitting on the bench I am modifying to run distributorless.
A good place to start with advance curve is with the Lucas standard dissy curve, then tweak from there. I haven't asked my engine builder for this yet, but this is where I plan to start.
Greg in France (10-19-2017)
Paul_59- That is a fabulous manual. Thank you for that. I learned two things I didn’t know: My 92 V12 XJS won’t throw a DTC unless there’s at least a gallon of gas in the tank, and if the throttle position sensor is wide open when cranking, the injectors are not fired. Both are applicable to my non-running car. Can’t wait to test that throttle position sensor and put a little more gas in the tank (it’s very low because I replaced fuel pump and only put a little in) -John
Timing for the HE is in the ROM it lists timing at 3 points in the RPM range, this is what I was planning to use as a basis for my Megasquirt.
Greg
dan02xk8
07-21-2016 05:22 AM
Dimitri_010
07-20-2016 10:49 PM
