2h just to fit some springs!?
#42
I think you're taking a lot of risk replacing a pair of front springs using a length of threaded bar and a couple of nuts and washers. The Jaguar recommended tool is specially constructed and most Jaguar agents will have one. It is made of high strength steel and allows the spring to be compressed, the spring pan to be removed and then the spring slowly released and lowered and a new spring inserted, compressed and the spring pan put back..
Great danger awaits anybody who cobbles together a spring compression tool with unknown material. These compressed springs have a lot of energy stored that if suddenly released can cause serious injury.
If the labour rate at a Jaguar dealer is one hour per spring that is a very good rate, and worth it. Even two hours a side is good, I'd say.
#43
How do you think the pans are attached to the wishbones? Magic? Nope. With 4 3/8" Unf screws. And they carry the entire compressed load. And the threaded rod method uses the same screw holes, just that the screws are 12" long instead of 1". It is also a tried and tested method by many users here.
Greg
#44
#45
Received 10,916 Likes
I've removed springs on a variety for cars and tried a couple different methods on Jags.
FWIW....
There is always reason to be a little nervous.... as that's what helps keep you safe. However, I've used the 4-threaded-rods method numerous times and it's as good as it gets as far as I'm concerned.
FWIW....
#46
Yeah, for a mere $716.65 ! (£588.79 !)
https://jaguar.service-solutions.com...ssor_(set)?c=3
Always good to remind everyone of the risks but the 4-threaded-rods method is tried and true....and within everyone's budget
#47
#48
#49
With the rod method it took me less than 30 minutes to do both sides... So 320 EUR für a 30 Min job... That is an hourly rate I'd like to be able to charge... 640 EUR/h if I go by my numbers...
MK2
10-11-2016 07:55 AM
FastKat
09-29-2012 09:06 PM
