3.6 fuel pump PLEASE HELP :-/
I’m in the process of restoring my 1990 3.6. Auto. The fuel pump is not whirring/priming. What can I do to trouble shoot this? I’ve looked in my manual for the location of the relay. It says it’s on the right side of the boot. However it’s definitely not there...please help as the electrical side of things can be very stressful for me 🤦*♂️
Hi Krakenfelt
Are you Sure that the Fuel Pump Relay is not in the Boot/Trunk and while I don't know where it is on the 3.6 on a V12 The Fuel Pump Relay is behind a Plastic Flap just by the side of the Boot/Trunk support strut (see photo)
The One in the Red Holder with the Red Stripe is the Main Relay and the one in the Black Holder is the Fuel Pump Relay and although they may look the same, they are NOT interchangeable
Have you tried putting 12 volts directly on the Fuel Pump to see if it works?
Greg in France (03-07-2019)
This is a pic I found. but if it is theres a black metal panel where you think the relay should be, look behind it. The panel might be bolted to the rear quarter but you can stick a camera or your head and get a view of 2-3 relays. This is what you might see. Right side of the boot, remove the carpeting molds btw
Hi Krakenfelt
This is where the Fuel Pump Relay is located on my 1995 XJS 4.0L (Facelift) same as that Photo from Brewtech, so you should be able to find it in one of those Two Locations
As on the 1990 Pre-Facelift it is usually found behind that Plastic Flap
In the following Photo, where the Fuel Pump Relay is tucked underneath the Fender/Wing, the Silver one is the Fuel Pump Relay, in between those two Blue ones
webbeing
08-18-2018 10:49 PM
car5car
05-18-2016 05:16 AM
driftr319
07-29-2011 12:30 PM
