3.6 mpg! That's not right!
To elaborate a bit on Mikey's answer....
The speedometer & odometer, trip computer, cruise control, and (when fitted) service interval counter all share a signal from the speedometer transducer which is located on the LH side of the transmission. The transducer is also described as a 'pulse generator'.
JigJag (08-30-2017)
What year is your XJ-S?
They switched to a differential mounted speed transducer (not sure which year) and the signal splits at a speed interface unit mounted in the trunk/boot, one goes to the trip computer and one goes to the speedometer. If one or the other works, but not both, the speed interface unit is the problem.
JigJag (08-30-2017)
As often as not just unplugging and re-plugging the TC clears erratic quirks. At least temporarily. I think these old TCs suffer degraded solder joints like so many other decades-old devices. The unplugging-replugging jostles the board enough restore the connection. It's the fiddle factor.
Worth a try before getting elbow-deep in dashboard wiring, perhaps.
JigJag (08-30-2017)
How does one remove the Trip computer?
