4L60e swap
I love the project. But I have to agree with not mounting cable to body and I've done some hairy crap before. I understand that its tight in there and you aren't done with the install yet. When I put the V8 in my Vega I found that the sledgehammer came in quite handy to make more room. You won't need to adjust the tunnel much and the carpet will hide the adjustment nicely.
Take your time and the solution will come to you.
Best of luck
Best of luck
I count my self luck I decided to replace the trans now. As I was getting ready to machine the converter mounting holes I noticed some marks in the flywheel.
So I got some fine sand paper and a flat block. DAMN the flywheel is cracked. I'll have to talk to a transmission shop and see if I can get a custom flex plate.
The way its cracked would lead me to think something was out of alignment. It did not look like the trans had ever been out of the car, but who knows.
I do need to find the cause before I bolt everything back up.
I'll carefully measure the TC run out and alignment when I replace the flexplate.
#32
+ From Engine (66783)
#34
Greg in France (10-07-2016)
#35
My car has 260,000 km on it so that's entirely possible. My guess is the trans input shaft bearing.
Also I weighted all the TH400 (with oil drained) parts including mounts and the 4L60 is 12kg lighter. The TC and drive shaft are 3kg lighter and this is reciprocating mass.
talk about rotating mass reduction, i listen to engine response , and it is quick, going up in rpm ,but most noticeable coming back to idle quicker!
warrjon (10-06-2016)
#36
I have driven my brother's 800hp Shelby and it comes back to idle almost instantly.
I have been keeping track of the weight reduction, including my engine build and it looks like I will be reducing rotating weight by at least 5kg. 3kg (possibly more as the internals of the trans are lighter) from the trans and 2kg in pistons and rods. The Chevy pistons are about 30-40g lighter than the Jag and the Rods will be nearly 100g lighter.
#37
Replacement flexplate on the Mill ready to slot the TC mounting holes.
I turned up a pin that fits in the collet chuck and centres the chuck and cutter in the hole. Move the bed to the other end and center the other hole so when I mill the slot it's straight.
I sanded the flexplate with emery cloth then scotchbrite to remove all of the edges on the nicks and edges.
The following 2 users liked this post by warrjon:
Greg in France (10-07-2016),
ronbros (10-07-2016)
#38
Greg in France (10-12-2016)
#39
#40
Almost there. Last test fit. I must have had the trans in and out at least 10 times, getting good at removing and installing.
I am not a big fan of in radiator oil coolers, so I bought a heatsink oil cooler. and plan on mounting it in front of the radiator. I need to relocate the connectors and pull the bonnet off. So I'll wait until the trans in and the car down on the ground. I also bought a Magnefine oil filter I plan on installing before the cooler.
Jonathan-W (10-20-2016)
