5.3 V12he Engine Harness
Depends on WHICH harness you need. There are...a few.
if you want new/oem there is a guy who makes them, I've had luck with his products both injector and gauge sensor harnesses all redone with new original plugs. Contact Andrew at JaguarSpecialties, he comes on the forum occasionally to.
Ashfro (03-21-2020)
These people (i have one of their injector harness in my XJS)
https://www.autosparks.co.uk/xj2312-...g-harness.html
If you also look under XJ12 you will find more there, they are not particularity well cross referenced, for example this is also the correct inj harness for my 82 XJS but not directled listed as so ........The harness on the other hand is superb.
