5.3 vs 6.0 heads
Received 1,236 Likes
OK , the 6.0 has a slightly larger chamber, so as to lower the comp.R a little. because of probs with detonation.
CFM? not much out there on HE , but there are some numbers for pre type. you could get a flow bench(mentioned here), and come up with your own numbers!
SERIOUS race guys dont. use HE heads for SERIOUS racing, simply because they just do not flow well at hi rpm, no matter what you do to them.
the HE exhaust valve area is prone to hot spots and dropped seats,along with possible detonation that can pound a bearing and then go into a spin.
the pre with big valves and a big bore with a top liner relief flows the highest CFM , of any Jag V12, you should be aware that just a hi CFM port flow does not mean you can get the air into the cylinder, or out of the cylinder.
as you are finding out,ther is a lot to building a hi-performance engine,and it aint cheap, even if you do the work yourself.
Broadspeed used flat heads and then machined chambers in the heads, they didn't run flat heads in the XJ-c.
The 6.0L heads flow better than 5.3 because the chambers are larger in order to keep CR at 10:1 or so depending on market.
I have attached a pic of both chambers. You could machine the 5.3 chambers to de-shroud the exhaust valve and smooth the step on the inlet. I was talking to the guy I bouht my 6.0L from he used to build V12 race engines for power boats and also built engines for the XJS racers. He believes opening out the chambers in the HE will work, not quite as good as starting from a flat head and machining but worth the effort.
The following 2 users liked this post by warrjon:
anyoldiron (10-07-2019),
someguywithajag (10-16-2016)
How long is a piece of string...lol
It depends if you leave the capacity at 5.3l and machine the chambers you will drop the CR. If you increase the capacity and leave the piston TDC the same deck height and do not increase the chamber volume you will increase you CR.
CR is the ratio of swept volume to compressed volume, so (for ease) lets say 5300/12 so each cylinder has a swept volume of 441.67cc if the volume above the piston at TDC is 44.167 your CR is 10:1.
If you increase the engine capcity to 7.0L and do not change the compressed volume your CR will be 13:1.
You need to first decide what configuration your engine will be If you decide on 6.5L then DO NOT change your mind.
Next you need to set the piston deck height. I would keep it stock so you have good squish. I think stock is Zero ie the piston is flush with the deck at TDC*********YOU NEED TO MEASURE THIS*************
TO set the deck height with the selected stroke requires the piston pin to be a certain distance from the piston crown.
Once you have this locked in stone then you can calculate your chamber volume, remember to take in account head gasket bore diameter and thickness. I would not go any thinner than 0.043thou on the gasket crushed.....
HI All.. I was trying to locate a set of 5.3 head studs and wonder if any one knows if there is a difference between a set of the studs for a 6.0 .. Im sure having a time trying to find a set and thought if they were the same , it gives me a broader search area... Thank you so much for any response. Mack
macksjaguar (11-04-2014)
From your photos its a bit hard to compare sizes, are the inlet's the same size on each?
Funny this has come up, as I am trying to find a design to alter the standard 5.3 HE heads to give a little more, I can see the difference in the exhaust but I need to get a little scale in the equation. With an NC mill you could easily alter the complete thing, any ideas there?
You will not get 12:1 from pre HE heads there is not enough squish.
performance tho.
also you can use a custom piston in the pre-he for both squish and turbulence, and raise the comp. ratio to at least 13-1
Greg
Warren
Talk to Eddie at Headstud Developments in Melbourne. He is probably one of the best head developers in the country. Worked on the Holden Bathurst development in the early days.
Here is what I would do
- Re-cut seats for multi angle (Thronleigh Cylinder heads can do this)
- CC chambers.
- Ceramic coat chambers and piston crowns.
- Match intake manifold. There is a very rough 45° angle cut in the head intake port where the manifold mates.
- Enlarge the exhaust manifold, Ceramic coat inside and out
If you leave the engine 5.3L then the chambers will need to be welded and re-shaped to keep CR around 10:1. Easiest way to make power in a Jag V12 is FI, a couple of Subaru TD04's low boost 6-9psi.
Ron the 5.3 valves are the same Part number as the 6.0L (valves did differ for market)
funny you mention the V12 mods,
my build of my V12 ion 1995, almost a repeat by you!
recut valves seats multicut angles to match oversize valves.
CERAMIC coat flat chambers and piston tops,plus coat exhaust ports(i consider important) in heads.
match inlet mani to head before internal abrasive machining/Extruded honing same.
enlarge exhaust manifolds then ceramic coat inside and out side to reduce under hood temps,and keep exh. flow velocity up, along with larger down pipes.
the pix you posted show a difference in head of valve, 5.3 are hollow tuliped, and the 6L show a flat top of valve, usually that indicates a better under head profile of the 5.3 valve, and reduced weight, of course best way is to hold the valves side by side!
as usual a may have been ahead of the curve back then, especially in the USA Jag world.
plus a number of other mods etc.
You could offset grind the crank to 74mm stroke and bore the liners to 92mm for about 6.0l
Or weld and grind the crank for 78mm stroke, about 6.2L
Or just bore to 92mm for 5.6L. I know 202 Holden pistons have been used in the V12 before.
Katoh (11-06-2014)
