5-speed manual conversion for V12, opinions please.
I have it on my todo list and so far have found only these guys, who offer complete swap solution.
Can someone please suggest different sources, or approach?
i found one of the vendors who sells the V12 bellhouse - manual trans adapter plate. with that, virtually all your problems are solved. theyre asking $550. =
http://www.5speeds.com/v12bell.html
for the sake of this forum, and all who are watching, please dont buy one of those outrageously expensive kits. do this project on a budget, do a write-up, and youll be a hero.
Hey Mish
Depends on how much torque you plan on putting through the box but these guys have a kit to fit the Toyota Supra box if you are only going mild, and it is not too over priced.
Welcome to Dellow Conversions
Being a non ABS car makes it a little simper You can add a Wilwood clutch to the existing pedal box.
cheers
Warren
cheers
Warren
Price list they emailed to me it's a year old but should not have changed dramatically.
I did not go down this road because of the ABS and horrendous cost of ABS manual pedal box. And the Supra box to take 600hp is as expensive as a TKO600.
1. Bell housing & pivot ball $550
2. Pilot bush $25
3. Clutch fork & clip $95
4. Thrust race and carrier $95
5. Clutch plate 10" $145
6. Clutch plate 10 ½” $185
7. Push rod $25
8. Rear cross member support $95
9. Speedo cable $95
10. Tailshaft yoke $145
11. Universal joint $75
12. Weld yoke $75
13. New steel billit flywheel $450
Toyota Supra 5-speed (fully reconditioned) $950
We supply an 20” shifter position standard with our boxes but we also produce a shifter at 14”, which suits very early Jags (pre 1979 approx.) $275
Quik -shifter 18” or 20 ½” $275
TOYOTA SUPRA 5-SPEED OVERDRIVE INTO JAGUAR
12 CYLINDER ENGINE
2. Pilot bush $25
7. Push rod $25
9. Speedo cable $95
12. Weld yoke $75
screw the kit. get the bellhouse adapter, whatever clutch and flywheel you need to make it work, a double overdrive or a 5 speed out of a camaro or firebird, a slave cylinder and a pedal out of said firebird or camaro, make whatever driveshaft mods necessary. done
War? what makes the ABS so much more expensive?
Do you know what a headache it is to replace rear diff on these, I just went through that and do not wish to ever touch it again, 2.88 for me it is!
I have just done a gear ratio swap that has taken 4 months and it is still not back in the car yet, so I know first hand what a PITA this is - however if I had to do it again with the experience I have gained it would be a lot easier.
Options
A spacer can be used on the 2.88 hemisphere to set the new crownwheel at the right pinion offset.
Heavy duty Dana 44 19 spline hemisphere and gears will fit into the salisbury diff. The pinion spline is different so a replacement yoke will be needed - but a lot of parts are direct Jeep replacements. This option gives a greater availability of ratios.
Options
scooternva
20
09-27-2023 11:25 AM
WinterJag
16
10-09-2015 07:49 PM
5speed, conversion, conversions, dellow, jaguar, kits, list, manual, speed, supra, swap, toyota, transmission, v12, xjs
