6.0 graded bearings
6.0 graded bearings
Ok guys, I have my 94 6.0 down to the bottom. I really feel it needs bearings. The upper shells all look great, crank looks great, yet the lower shells all have dark gray where the bearing shell has worn. I called one supplier today, and they said they couldn't help. I have all the grades off of the crank. Any suggestions?
super i used a new set of Vandervell steel backed aluminum bearings, standard size, both rods and mains, a light micro-polish on the crank(set in a lathe,very slow turn).
been 20 odd yrs still carries excellant oil pressure, hot or cold.
i'm not sure if they are still available, but it seems that KING engine bearing, are the hot setup, at least lately.
they are a steel backed aluminum bearing specialist today, bought the license and patent rights from GM/Moraine, very much used by factory backed Corvette race cars.
The following 2 users liked this post by warrjon:
ronbros (08-11-2015),
superchargedtr6 (08-11-2015)
Spend 10 minutes plastic gauging them. To find out if you really need new bearings.
Clearance should be between .007 & .013.
it sells on line for $11.87 a package. Or you can buy enough to check several engines for about $30.00
Are you sure about that? 6 liter journals literally specced as much as a .0011" difference. That's even too much for me and my standards are stoopingly low! But maybe that PDF was overstating the possible variances which is very possible. https://www.google.com/url?sa=t&sour...sVOCuqQUdWh6xx
All I know is I found a company who has all three grades in stock. https://handlerparts.de/en/Search?code=Jlm1113803
Pretty sure the page was auto translated from German to English for some reason. Calling the Monday morning. They are nein hours ahead of me.
Greg in France (06-12-2020)
