6.7L V12 build
Old 03-30-2018, 04:57 AM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
When the second water rail is finished I will start on making aluminium 1/2 moon seals.
Stay tuned................
  #442
Old 03-30-2018, 05:49 AM
xjsv12's Avatar
The aluminium half moon on S-type V6 first generation , with a small modification.
The following 3 users liked this post by xjsv12:
FerrariGuy (03-31-2018), Jonathan-W (05-01-2020), ronbros (03-31-2018)
  #443
Old 04-02-2018, 07:21 AM
xjsv12's Avatar
Alum insert half moon part number XR85240
https://www.britishparts.co.uk/jagua...d-insert-p6553
Greg in France (04-16-2018)
  #444
Old 04-16-2018, 04:34 AM
warrjon's Avatar
Got my new milling machine set up and finished shortening the inlet valve stems. The digital quill depth gauge made this much quicker.
I'm off to Melbourne on this Saturday with the heads for Norm to bolt them on. Hopefully not too long now I'll have the engine back.
The following 3 users liked this post by warrjon:
Greg in France (04-16-2018), ronbros (04-16-2018), xjsv12 (04-18-2018)
  #445
Old 04-16-2018, 01:21 PM
LongJohn's Avatar
Hey Warren, Very exciting. I’m watching, learning and enjoying. Good luck John
  #446
Old 08-30-2018, 02:59 AM
warrjon's Avatar
I know I haven't updated this for a while, I have been buying tools in order to make a few bits and pieces, on the todo list are custom intake manifolds, Aluminium 1/2 moon seals. Also Norm has been unwell so progress has been slow. I now have full inhouse machining capability. If I had this mill earlier I would have done all the machining. this will will fit a V12 engine block on the table.
Plan is as soon as I have the mill running are to fabricate new intake manifolds that look stock
A good ol pommie lathe
Yes that is a 6' ladder behind the mill
The following 2 users liked this post by warrjon:
LongJohn (08-30-2018), ronbros (09-03-2018)
  #447
Old 08-30-2018, 04:50 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Awesome! Looking forward to seeing the results. I assume you'll be welding some alloy tubes to a nice sized plenum to replicate the original look?
  #448
Old 08-30-2018, 06:35 AM
warrjon's Avatar
I was thinking of fiberglass plenum and runners fixed to an aluminium flange. Plenum will have aluminium molded in for TB mounts.
  #449
Old 08-30-2018, 12:06 PM
LongJohn's Avatar
Sounds brilliant. Can you taper the fiberglass runners?
  #450
Old 08-31-2018, 03:30 AM
warrjon's Avatar
I was thinking about that but after doing some research tapered runners are probably not going to add anything in my engine, so most likely straight. I was thinking how I will mold , them, probably use a PVC pipe and bladder.
  #451
Old 08-31-2018, 11:56 AM
LongJohn's Avatar
Warren check out this plug...
Mabye a plug made from copper pipe would be easier and use carbon fiber sleeving instead of the stuff he used.
  #452
Old 08-31-2018, 05:40 PM
warrjon's Avatar
Yes I saw that one.
This is the way I was thinking, like they make bike frames
DIY How to Carbon Fiber Tubes & piping for Intakes how to ~ Carbon Fiber Fiberglass DIY how to Guides
  #453
Old 09-03-2018, 02:40 PM
LongJohn's Avatar
Warren you have some serious machines and skills.
Yes I saw that one.
  #454
Old 03-19-2019, 09:30 AM
Addicted2boost's Avatar
Received 1,100 Likes on 845 Posts
Any updates on this engine?
ronbros (03-19-2019)
  #455
Old 03-19-2019, 03:03 PM
warrjon's Avatar
Norm was ill for a while which stalled the build. I had lunch with him Monday and the pistons are done and ready to start assembling the engine.
I will update as things progress. I have not abandoned this project, way to many $$$ in it now.
  #456
Old 03-20-2019, 12:36 PM
Fla Steve's Avatar
Totally impressed with your machine shop. You are a machinist as well as an electrical engineer.
You Daa Man as they say!
  #457
Old 03-20-2019, 03:07 PM
warrjon's Avatar
My trade is electronics and I grew up in a machine shop, my dad was a tool maker and had his own injection moulding shop.
I just love designing, making and repairing thinkgs
The following 4 users liked this post by warrjon:
Jonathan-W (05-01-2020), Mike1610 (05-03-2020), Robert Vautin (01-14-2020), ronbros (03-20-2019)
  #458
Old 02-09-2020, 06:27 AM
Any more movement on this project?
  #459
Old 05-01-2020, 12:10 PM
Jonathan-W's Avatar
Smile
hey
have not heard from you in awhile... I hope this message is finding you well in these trying times...
Jonathan
  #460
Old 02-17-2021, 08:30 AM
Updates??
Quick Reply: 6.7L V12 build
