6.7L V12 build
Old 12-10-2016, 04:07 PM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Only one position... I like to hear that!
Domyou know, out of your mind, if the front crank seal must be replaced on the steel sleeve? All pictures and items I find of the front seal, all show a steel 'tube' in the middle...!?
  #82
Old 12-10-2016, 04:46 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
Yes the front crank seal comes in a kit with the rubber seal and the sleeve. Good idea to replace it while your engine is out, they ALL leak with age. Mine is leaking quite badly but I'm not going to replace it as the engine will be replaced.
  #83
Old 12-10-2016, 05:05 PM
Daim's Avatar
Is the sleeve something just to 'carry' the ring until it is fitted or is the fsleeve installed at the same time?
  #84
Old 12-10-2016, 06:21 PM
warrjon's Avatar
It stays there.
Have a read of this from Bernard Embden, he did a very good write up on how to replace it.
Replacing The Front Crankshaft Seal
The following 3 users liked this post by warrjon:
Daim (12-11-2016), Greg in France (12-12-2016), Jonathan-W (12-12-2016)
  #85
Old 12-11-2016, 04:29 AM
Daim's Avatar
Warren, gracie mille!
Seems like the AJ26 version with a spacer... Now I know what I'm looking at... Cheers again!
  #86
Old 12-11-2016, 04:51 AM
warrjon's Avatar
Made up a couple of templates today to assist in getting each chamber as close as possible to the same.
This clear perspex template took hours to get exactly right.
It's hard to see in this pic but the perspex is in place.
Chambers marked up ready for grinding.
The following 7 users liked this post by warrjon:
Daim (12-11-2016), FerrariGuy (07-01-2017), Greg in France (12-12-2016), JagZilla (12-12-2016), Jonathan-W (12-12-2016), ronbros (12-11-2016), xjsv12 (12-15-2016) and 2 others liked this post. (Show less...)
  #87
Old 12-11-2016, 05:16 AM
Daim's Avatar
Great idea! And they look professionally done... Though I doubt a pro would do it that way to that extent of precission!
  #88
Old 12-12-2016, 12:35 AM
xjr5006's Avatar
Just received a TWR v12 6.7L to sort out as its got problems, I'll post some pics when its all opened up.
The following 5 users liked this post by xjr5006:
Daim (12-14-2016), Greg in France (12-12-2016), Jonathan-W (12-12-2016), ronbros (12-12-2016), xjsv12 (12-15-2016)
  #89
Old 12-14-2016, 12:23 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
Talking
great idea , post a few specs also, like bore/ stroke, chamber pix anything relevant to the few go faster guys?
thx ron
  #90
Old 12-14-2016, 05:02 PM
melhookv12's Avatar
are these the heads you are using or just dummy ones ?
  #91
Old 12-14-2016, 10:40 PM
warrjon's Avatar
These are the heads that will be going on the engine.
  #92
Old 12-14-2016, 10:49 PM
warrjon's Avatar
All 12 chamber roughed out. About 20hrs work in them so far.
I'm waiting on the new valves to arrive and they will be ceramic coated before heading off to the machine shop. Once the head is planed and the valve seats re-cut I'll cc the chambers and match them up.
Jonathan-W (12-15-2016), ronbros (12-15-2016), xjsv12 (12-15-2016)
  #93
Old 12-15-2016, 03:29 AM
xjsv12's Avatar
Hi Warren
Are you rounded ports?
This hard work is really help
The following 2 users liked this post by xjsv12:
FerrariGuy (07-01-2017), ronbros (12-15-2016)
  #94
Old 12-15-2016, 10:11 AM
Jonathan-W's Avatar
Originally Posted by xjsv12
Hi Warren
do you use a bottle brush hone to do that ?
  #95
Old 12-15-2016, 10:16 AM
Jonathan-W's Avatar
wow... might print and frame that! beautiful!
  #96
Old 12-15-2016, 10:31 AM
Daim's Avatar
Looking good mate!
Stupid question: how do you 'cc' it? With water or some kind of fluid or with sand or so?
  #97
Old 12-15-2016, 11:04 AM
melhookv12's Avatar
Looks like they could do with a skim to clean them up?? Is that in the plans. ?
  #98
Old 12-15-2016, 11:34 AM
xjsv12's Avatar
I 'll put pics tomorrow
  #99
Old 12-15-2016, 12:45 PM
melhookv12's Avatar
just read your other post.
I'll get my coat !!
  #100
Old 12-15-2016, 01:00 PM
xjsv12's Avatar
I'll get my coat !!
all parts will be cleaned twice or thrice
Quick Reply: 6.7L V12 build
