700R4 Quarterbreed conversion by John's Cars
If you want an extra 5% off put this code in the "how did you hear about us" box at checkout. It's good until Sept 6.
Code:144713179131134072
The following 2 users liked this post by Jagboi64:
Dukejag (07-10-2020),
Greg in France (07-10-2020)
Right here: https://www.rockauto.com/en/moreinfo...1923&jsn=14642 It's $32.79
Thanks, I don't find that same Amazon view, can you post a link? Mine shows out of stock
When I had Summit in the cart yesterday it showed September delivery. At least that's an improvement.
SDPC shows available but when I called they said it wasn't.
Thanks for checking
Thanks for checking
You can see the notch on the Bell housing below the dowel hole where the starter bolt sits
A drill bit, this hole drilling tool and a round flat combo file made this pretty easy.
https://www.amazon.ca/dp/B001UE93LW/..._gKhcFbMFGQG14
Because its canada it might be able to ship to you though. Keep me.posted.
Thanks for that.
#30
#31
#32
Huge issue to consider.. Throttle Valve cable
It arrived today so I'm back on track.
I notified John that this will be an issue but haven't heard back. His instructions advise against a universal cable. Something to think about if your considering this swap.
Greg in France (07-15-2020)
#34
#36
#37
A 160-mile round trip last week, with some mixed city driving and some cruising (but no interstate) netted around 26.5.
Jess
#38
Stupid question
Has anyone ever looked at putting a modern transmission in an XJS? Having seen all the work that Xjeffs went through with the Quarterbreed conversion, it seems like a lot of effort to put in a tranny designed in the 1980s.
A 6 speed electronically controlled transmission would seem better suited to keep the car in the sweet spot of the torque curve and offer the option of “manu-matic” shifting without the need for a separate clutch.
Is there just not enough of a market for someone to justify doing the engineering work to design a conversion kit?
#39
#40
