83 XJS Salisbury differential drain plug help
1983 XJS . Hi,hoping you guys can help. I changed the differential fluid a few days ago and now it's leaking from the bottom plug.previous owner had it in there halfway threaded in. Never seen that before. Didn't see any thread damage but I'm sure there is. Anyway,what would you recommend in this situation? Help
v1rok (08-01-2019)
Agreed,
1/2"BSP from memory??
ALWAYS some sport of sealer on those threads, its "steel on steel" as we say.
Only choice, drain it again, let it drip out, HOT is Vegas at the moment, so drink beer for an hour or 2, then refit WITH sealer, and refill the diff, simple.
DO NOT get stupid with a long bar etc, you WILL snap it off and be in more shiit.
v1rok (08-06-2019)
[QUOTE=Grant Francis;2107108]Agreed,
DO NOT get stupid with a long bar etc, you WILL snap it off and be in more shiit.[/QUOTEPut on loctite took my time went on easily no leaks. Thank you
Grant Francis (08-06-2019)
scrible
10-24-2012 10:01 PM
