85 5.3 HE No Start Goofyness
Hey guys. I am, once again, another fool who decided to pick up a non-running beautiful example of a V12 Jaguar. I guess I am glutton for punishment. ![Icon Stooge](https://www.jaguarforums.com/forum/images/smilies/icon_stooge.gif)
Anyway, between resources here and elsewhere, I managed to go from a no crank to cranking, which is a good start. Apparently the starter relay has gone bad and I bypassed it with a standard relay based off of the instructions here:
Jaguar Specialties
She cranks over no problem now, but I do have left over wires from the original starter relay. Are these used anymore?
I also traced the no start back to the fuel pump being dead. From the looks of it, they already tried replacing it with a Walbro, which looks like a nice unit, but it appears to be dead already. Is there a chance that the filter sock in the smaller sump tank clogged it and killed it? I did notice cracks in the bigger hose that comes from the sump to the fuel pump that needs to be replaced, is this 1/2" hose?
Another goofy thing I noticed is a speedo bounce. Shouldn't the tach bounce instead? I've already managed to "drive" the car a mile and it hasn't moved an inch!
Anyway, thanks for the help and I can't wait to get this beauty up and going!
Jaguar Specialties
As for the fuel pump, I did just test it directly with the battery and nothing. Before, I could hear the fuel pump relay click off after the 2 second prime.
There was an old school keypad security system in the car at one point, and taking a part some of the lower dash panels, it looks like the system was removed and things spliced back in normally. They did leave the non-functioning keypad in though. I feel like I will be cleaning up hacked wiring before getting to the original mess.
One reason I walk away from cars I want to buy: wiring interference. I hate it when people cut into and trim wires how they want. You can search for years... I'd recommend getting a manual with the wiring diagrammes to make sure everything is correct and then check. Do one task at a time. If you have no spark, work to get a spark. If then still have no fuel, work and see if you can get that done.
The following 3 users liked this post by Daim:
Received 10,872 Likes
What are the colors of the left over wires?
If one of them is white/red ....a smaller gauge than the white/red that goes to the starter.....it might be worth investigating. It gives the ECU a 'start signal' according the S57 diagrams.
I *think* what it actually does, more specifically, is tell that the ECU the engine is being cranked by the starter so it (the ECU) can A) turn the fuel pump on and B) increase the injector pulse width slightly for a slightly richer mixture
Speedo bounce when cranking often suggests a voltage drop problem....poor supply voltage or poor grounding....which may or may not be related to your no-start situation.
*IF* you have a voltage drop problem to the speedo then you might well have a voltage drop problem to the F.I. system as well....which might prevent the F.I. system from working properly. These F.I. systems really like lots of volts and amps !
The following 3 users liked this post by Doug:
I'm just more curious about the speedo bounce instead of the tach bounce. Is that normal behavior or did someone reverse some wires somewhere?
Possibly.
As for the gauges, I assume it's at the gauges themselves. I am also getting 9V at the gauge while I can clearly read 12V+ at other various locations (at the starter relay brown wire for instance).
or does the starter relay act as multiple relays to handle the different levels of current?
No.
The original relays simply had multiple exterior posts connected to the same contacts internally....to accommodate this sort of situation.
An optional solution would be using a "dual 87" relay. Same at what is shown in the Jaguar Specialties tech-tip but it has two '87' terminals rather than 87 and 87A
dannyS
07-22-2013 11:12 PM
YYC guy
01-21-2012 03:45 PM
mojoworld
05-24-2011 06:19 PM
