86 xjs --key won't work
Received 10,895 Likes
1 key has always fit all 3-- now only ignition works
neighbor & friend both picked the lock and said it wouldn't turn even when picked-- door and trunk both
I think the automatic lock has my system frozen in lock mode, I pulled this info off another site but after I got into the kick panels like it suggests-- none of the wire colors match up to any 4 wire plug and the wires onto the solenoid are different colors
Disconnect the 4 wire plug on the drivers solenoid and with a test light check to see that the "Black" wire on the harness is a ground. The "Purple" wire is power. Apply 12v to the "Orange w/green" wire to lock the 3 doors and trunk. Apply 12v to the "Orange w/Red" wire to unlock the 3 doors. To test each relay apply 12v one at a time to each "Orange w/green" wire on the "C1" and "C4" position on the "Lock" relay to lock the 3 doors and trunk. Then apply 12v one at a time to the "C1 and "C4" position on the "Unlock" relay to unlock the 3 doors only. With these tests you should be able to isolate the problem.
Odd about the key. On my 87 and 88 Jags the door key was different from the igntion key.
If you're thinking the lock system is electrically "stuck" you could pull a wire off the thermal breaker to cut the power and see if anything changes. This won't explain the trunk lock, though, as an '86 won't have a solenoid there....unless it was an add-on.
You might wanna pull the door panels to check/clean/inspect the linkages from the key cylinders to the door latch. Maybe they've rusted up? Same for the trunk lock?
All *three* locks suddenly rusting tight all at once is quite a stretch, though.
Start by pulling fuse no 8 in the main fuse block. In an '86 that should depower both solenoids. And as written in a previous post the boot didn't have solenoid in '86. If that does the trick one of the door switches is dead in the LOCK position. If no change continue as described abobe, most likely the LOCK relay is stuck in the lock position. The thermal circuit brakers should trip time and time again though so in between it should be possible to open. If you do not hear any clicking in between and it is not possible to unlock at any time maybe a short to +12V in the LOCK solenoid feed wire. Alternatively a dirty contact or broken wire / deat UNLOCK relay.
Well, the fundamentals of the system are the same either way.
Unless the locks have been changed/re-coded you really *should* have a different key for the exterior locks versus the ignition key/lock
Frankly, I'd follow up on that angle before doing anything else
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
SingBlueSilver
08-27-2015 02:20 PM
