86 XJS V12 Power Steering Pump
Old 04-26-2017, 10:22 AM
Anglicomarine0326's Avatar
Default 86 XJS V12 Power Steering Pump
My pump leaks like a sieve, and I'm currently driving it without the unit working. It needs replacement and rebuilt pumps are cheap. Question is: How difficult is it to remove and replace myself? Nothing on this car is ever easy!
Old 05-24-2017, 05:17 PM
Edward 74's Avatar
i just did the pump which was easy for this car but i still have a leak from somewhere. the lines i didnt do which would have been a nightmare
Old 05-24-2017, 05:22 PM
You're right, it's the one component that's fairly accessible. I can't trace my leak from looking under the hood. The pump comes alive with fluid added. Stop leak slowed it but it still pisses the fluid out. I hope it's not the high pressure line and maybe a split hose. I won't know until it's on a lift. Funny thing is, it drives nice without power steering. Parking in a crowded lot is tough though.
Old 05-24-2017, 08:32 PM
Edward 74's Avatar
there is an o ring that goes on the intake line which is high presseure. replace that if you didnt put it in. if not its something else. either way its an inferior system to the later HE models
Greg in France (05-26-2017)
Old 05-24-2017, 08:39 PM
I'm no mechanic, but is this the hose end that attaches to the pump, or steering rack?
Old 05-25-2017, 02:29 AM
GGG is offline
Received 16,862 Likes on 12,186 Posts
Welcome to the forum Anglicomarine0326,
I've moved your question from US Northeast Region to XJS forum. The Region forums are for geographically relevant posts; the Model forums are the appropriate place to post techncial questions.
Old 05-25-2017, 08:53 PM
Mac Allan's Avatar
I believe it is more likely that you have a hose leak. The heat shielding around the hose tends to direct leak flow either toward the steering rack or the pump. Therefore don't assume it is the pump just because there is fluid dripping from that location.
Old 05-26-2017, 07:55 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
wish i could help, but when my pump started leaking, i now use a 1997 Dodge Viper V10 pump, changed mounting brackets and hoses to fit!
very light weight,saved around 8lbs, from the cast iron GM /delco pump!
Attached Thumbnails 86 XJS V12 Power Steering Pump-jaguar-engine-build-process-001.jpg
xjsv12 (05-30-2017)
