86 XJS V12 Power Window Failure
Got a bit of a dellima on my hands. Windows worked fine when I parked the car outside to let it air out and now they wont go up and I'm not sure where to start looking. I've seen a thermal breaker in several wiring diagrams but cannot find it on the car. Any help would be greatly appreciated.
Received 10,910 Likes
Agreed on the switches....common problem. A bit odd both failing at once, though.
The thermal breaker is probably on the RH component panel, below/behind the glove box. About 1.25" square, had brown and brown/blue wires. The window relay nearby as I recall.....the brown/blue wires goes to it
99xk8guy
06-05-2023 06:28 AM
