86XJS COUPE Dana oil change, need help.
Have just replaced discs and shocks and before replacing crossmember I thought it might be prudent to change the oil. Since the Dana rear end has friction clutches, I am not sure what oil I should put in there and if any additives are required. Is Red Line 75/90GL-5 OK and would I need to add friction modifier to this?
Thanks in advance for any suggestions.
Received 10,920 Likes
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
