87 Octane VS 93 Octane
I have the choice in my area (South Carolina) of running 93 Octane premium (10% ethanol) or 90 Octane (No ethanol).
I have been running 90 ethanol free, and the engine seems good with it. I really don't like ethanol. Will the lower octane hurt?
Comments??
Thanks...Jimmy
PS...Merry Christmas!
Comments??
Thanks...Jimmy
Received 2,399 Likes
Received 2,263 Likes
Greg in France (12-24-2016)
...Jimmy
...Jimmy
Maybe you can get 93, most of North America cannot. Unheard of in CA I think.
Ethanol is a separate unrelated issue.
#28
No one has mentioned that high octane fuels are cleaner than low octane fuels , meaning less "gum" build up through the ENTIRE fuel system and less changing of fuel filters .If you are eco minded it also has less emissions and generally will give a slight improvement in fuel economy .IMO there is nothing wrong with E10 but the vehicle must state that it is suitable for E10 or as a member has already stated the fuel hoses will break down , another obvious solution is to change the fuel hoses to a type suitable for ethanol ,double check at the auto store.
#30
My wifes last car (a C300 Mercedes) called for 93. Her new car (Acura) requires 93 all per the manual.
According to Google, 93 is available just about everywhere, except the west coast.
Lastly...I screwed up, the 94 Jag V12 requires 95 RON by the Manual which relates to 91 Octane and means that the 90 (no ethanol) that I am using is cool.
THANKS....Jimmy
Greg in France (12-27-2016)
#31
It appears that vehicles in your neck of the woods , came out much much earlier than in Australia . I will check the web site you mention , right now our government is considering banning all low octane fuels as a measure to improve emissions and protect the environment ( doesn't mean they are right!) on top of that , many car mechanics and some car organisations etc recommend using 98 octane in about 1 in 4/5 tank fills to clean the system if using " standard fuels " ie 91octane here in Australia . Our vehicles here have a sticker saying E10 suitable at the fuel cap. My imported 95 Camero has no" sticker " saying that it is safe to use Ethanol type fuels ! but I will check the OM .All in all it is getting harder to know what is right or wrong but for my jags 96/98 octane rating is all I would use . I suppose we could ask the oil companies , they wouldn't lie would they.
#32
#33
#34
Whew???
That octane thing again. My two cars do just fine on 87!!! 94 Jeep I6, well over 200 miles on the odo.
83 Jaguar wuzza 6, now powered by an LT1 sourced from a 94 Cadillac Fleetwood Brougham. Admired at the gas station yesterday, by a fellow car nut... He noted the V8 badge above the XJ6 badge astern.
Others have noted the distinctive V8 burble in the exhaust note.
Why buy the premium stuff if your engine does not need it? Politicos making fuel decisions. yowee....
Carl
Carl
#35
Received 10,872 Likes
In the USA, at least, I think you have a problem finding hoses that are not E10 compatible....because E10 has been around for so long. It varies by region but in my neck o' the woods (Pacific NW) E10 has been ubiquitous for at least 20 years
As for Jaguars, the owners manual or my 1988 say E10 is OK....so Jaguar was aware of E10 requirements at least that far back
#36
I expect you guys know, but in case not in everyone's case, in Europe and the UK, octanes are rated in RONs (research octane number) whereas I have heard that in the USA the same petrol is rated in MONs (motor octane number), which gives a lower number for the identical stuff. A bit like centigrade and Fahrenheit. Quite often this causes confusion too.
Greg
Greg
#37
Gas in North America, not just USA, is rated by AKI (anti knock index) which is the average of RON+MON.
We used the RON scale until the mid 1970s until some bright spark decided to confuse everybody. Owners of older cars (pre-mid 70s) sometimes get confused when they see mention of their old Ford or Chev needing 95 or 98, thinking they need to buy 'racing' gas to get that octane level.
Generally speaking there's a spread of 4-5 points between RON rated fuel and the AKI rating.
Euro 95 is identical in octane rating to N.Am 91.
#38
#39
BP themselves says 5,000 miles.
Look it up.
#40
Let's throw in a new twist.
They just opened up a new WA WA Gas Station. The place is packed.....Great Restaurant!!!
On to my point....They sell an 89 Octane w/o ethanol. They call it recreational fuel...for Boats, etc.
Would this be better than the 87 Octane w/ethanol...Probably....but what about the 93 octane w/ethanol.
By the way the recreational fuel is currently @ $2.65/US Gal. vs the 93 octane w/ethanol @ $2.79/US Gal.
Let's really get this conversation going!!!!!!!!
Happy Holidays
Softball60/Paul
1996 XJS 4.0L 2+2, 1989 Merc. 560SL 1957 XK140 Drop Head and every other British Sports Car known to Mankind
Happy Holidays
Softball60/Paul
