88 5.3 starts and runs but....
Just reading this and following the advice and events then.... "back on the road" so just for the benefit of the forum what did you find? unless I am missing something here? one minute your timing was jumping around and now its "running good" did it fix its self or just suddenly start running ok?
cheers
cheers
Sorry guys , I was pressed for time recently , took a few days to get back
When I changed the distributor on the car the timing stopped jumping around . I haven't pulled the old one apart yet tho. The distributors power wire was broken and held together with the plastic coating which is what was causing the car to die when I turned the distributor.
The water temp sensor plug was only sitting in place and not actually plugged in. It made contact which allowed it to start but vibrated loose, then didn't restart .
Finaly a few days ago When I unplugged the distributor power wires the female connector came out attached to the male end. When I plugged it back in I think it made contact sometimes. It took a few days to find that one and who knows how long it's been like that.
So basically my car had a pooched distributor.,the replacement that came with the car wasn't any better but between the two I have one working dizzy.
Thanks again thugs
Thanks again thugs
The following 2 users liked this post by Al Whitelock:
Grant Francis (11-12-2015),
Greg in France (11-12-2015)
3jagfamily
10-01-2015 01:49 AM
