88 V12 ABS yellow warning light flashing
Is your Accumulator original?
I replaced mine with a Bosch accumulator that fits some Mercedes and Maybachs and is more widely available. Works great. Part number is 0265202070, and it used be about $70 on Amazon but the price has nearly doubled. Summit Racing says they'll special order if for you for $85.99:
https://www.summitracing.com/parts/bch-0265202070
Quentin,
I'd suggest a 30sec pump run from cold, and then a recharge kicking in after 3 uses of the brakes is absolutely fine. Very similar to my own. I wouldn't be looking to change the accumulator based on that.
I would start by doing a blink test on the system to verify what fault codes have been thrown by the system as a result of the light coming on.
It's very speculative but I wonder if a pulsing light could be indicative of a failing wheel sensor? Is the flashing frequency influenced by the speed of the car when you touch the brakes?
Anyway, let us know what codes it shows.
Paul
Paul
Mac Allan (10-24-2023)
Yes I would suspect the accumulator, particularly since it was replaced with a used one. Even NOS might be problematic depending on when it was manufactured.
Yes, I was just looking at the very same one.
Quentin,
Paul
Paul
Ahhhhh......... a different opinion!
The flashing only occurred occasionally, so not sure if the pulse rate is proportional to vehicle speed or not.
Will do the blink test as you say when I return from a work trip at weeks end.
end. Thanks!
I just went out and timed mine from cold (several days) and pump stopped at 23 secs.
Here is what can trigger the yellow warning light:
It's the flashing or intermittent nature that makes me suspect the accumulator is getting tired. Most of the above will fully light the ABS warning, the other possibility is an intermittent wiring issue. I don't usually recommend throwing parts at a problem, but while the Bosch accumulators are still available at a reasonable price it might be worth eliminating that as potential cause, and knowing you have a good unit that you won't have to worry about for years.
But agree with Paul that you should see what codes flash first.
ptjs1 (10-24-2023)
So I had my diagnosis process mixed up. I gather a tired accumulator is indicated by 3-5 pumps for the pedal to go hard (ign turned off), not 3-5 pumps for the pump to reactivate (ign on).
So...........
I went in search of what I believe is the elusive brown connector which I need to short in order to do the ABS blink test. No sign of the connector?
I also let the ABS pump fully charge the accumulator (30 sec), then turned off the ignition. Got 35 pedal strokes before the pedal went hard. Seems the accumulator is healthy.
Am I correct in thinking some cars didn't have the ABS ecu brown connector for doing a blink test?
If so, what next? 😞
If so, what next? 😞
Quentin,
It'll be a taped up part of that wiring loom which ultimately is attached to the ABS wiring plug. Carefully examine the wiring back from the plug and there's a taped up bit. I can see one taped up bit in your photo, but can't see the colours clearly enough to see if it is the right one.
Also got your PM and I'll send you the doc tonight.
Paul
Paul
