'88 V12 non runner - Resolved
Hello,
I need advice on my '88 XJS V12
Everything was fine, car was running great till yesterday. I started the engine and pulled car from the garage in the morning. It was running for couple minutes without any issues.
Few hours later I tried to start the engine and it ran for 2-3 seconds and stalled. For me It sounded like flooding so I tried to start it again and again. With full throttle it almost started, but no luck.
I was sure it was flooded so I disconnected all injectors (unplugged the harness on the right side of engine bay) After that I was able to start the engine for couple of seconds. After connecting the injectors harness engine immediately stalled. I tried it several times with no luck Any suggestions guys ?
Regards
Paul
P.S.
I recently installed new plugs, wires, cap+rotor, air cleaners, o2 sensors etc
Regards
Paul
P.S.
Received 10,979 Likes
Thanks for your suggestions !
I will try to check the pressure and the wiring today.
There is one more thing - while cranking I can hear the injectors. I am not sure if all of them works but they still clicks.
@JameyXJ6, which module you talking about ? I mean where it is located ?
Thanks again
Paul
Thanks again
Paul
Just for giggles.....
Check the connector and wiring at the coolant temp sensor.
If the circuit is open a running engine will flat-out die, and an a non-running engine will never start.
Over the years I've heard that an open CTS circuit will either cause massive over-fueling OR totally shuts off the injectors. Opinions differ and I've never heard a conclusive answer.
Anyhow, it's really to check, so....
Paul
FS[Western US]: XJS V12 Convertible
marklcap
09-29-2015 12:41 PM
